Vizio tv sound cuts out every 15 seconds.
I have a 3 year old vizio m551d-a2 and recently the sound started cutting out. Every 15 seconds or so the sound cuts out for a full second and comes right back. It does this from the moment I turn the tv on. Everything else is fine when the sound cuts. The video continues playing as usual. I've tried turning off any audio settings that might be the cause including the volume leveling and so far nothing has worked. Im just trying to figure out if I should buy replacement speakers or if there is another solution. Thanks in advance.
Bu iyi bir soru mu?
5 Yorum
Were you able to find a fix? I have been having the same issue with mine. 1 year old tv.
Jen korrell tarafından
My sound keeps go out as well. Noth
Tina palverento tarafından
How can I fix my TV VIZON every time I change the channel there a lady talking (may channel may channel )
Blanca tarafından
This isn’t solved, can we get a resolution?
Nono nono tarafından
I found if I go to settings and with the tv on HDMI 1 go to picture and then to input picture settings and the to hdmi mode and select compatibility. Mine was on auto and when I switched it I haven’t had any issues.
Kenny Giles tarafından
