Ana içeriğe geç
10 MP camera with 20x wide angle optical image stabilized zoom. Released in December 2008.
10 Soru Tümünü görüntüle
SX10IS Corroded battery damaged the contacts
The battery door was stuck. I manged
to coax it open after a long ordeal with a tiny screwdriver. Battery leak had damaged the terminals on the inside of that door. I cleaned them as well as I could but one of them is very badly corroded. It easily detatched fro the door but won’t fit securely back. Can I replace the door itself?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I doubt you’d be able to find parts for it. Try epoxy for structural repairs or hot glue for just keeping things in place.
Use rechargeablesifyou can. If there’s an external charging port, seal the batteries up so it doesn’t fall apart and use it as long as you can.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Jim DiNatale sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 229
