My monitor is double imaging pictures jumping with horizontal lines problem
Display problem with double images jumping and horizontal lines how to fix in my Samsung LCD panel LTM 190M2-L31
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Have you tried it on another computer or with a different cable (vga/dvi/hdmi)?
Bu yanıt yardımcı oldu mu?
Ruby Sahu since you already tried a different monitor and different cables, the issue will be inside your monitor. It is possible that this is caused by a bad video scaler on your board. You will have to disassemble it and take a look at the board for obvious damage like domed or leaking capacitors. Post some images of the board with yuor question so that we can see what you see. Use this guide Adding images to an existing question for that. Also, post some pictures of what your dispaly shows hen you start it up. It is possible that this is caused by a bad LCD driver board,. Replacement panels are available but a bit expensive. Let us know what exact model your monitor is.
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 452
Yes, I tried all that but it is only on lcd penal problem (doubt).
Ruby Sahu tarafından
