Ana içeriğe geç
A Kenmore residential washing machine made between 2001 and 2009. Identify the age of your Kenmore washer with its serial number.
dripping water inside the tub
dripping water inside tub but the washer is not running
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
What is the full model number of the washing machine?
You may have a faulty water inlet solenoid valve in the washing machine, not closing properly.
Try turning off the hot water tap which supplies the machine and check if the dripping stops. If it doesn’t then try turning off the cold water tap which supplies the machine to determine which solenoid valve may be the problem.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
ivan_mcneely sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 6
Her zaman: 764
