Ana içeriğe geç
iPad Mini 4— A1538 modelinin Wi-Fi versiyonu için kılavuzlar. 9 Eylül 2015'te duyurulan iPad Mini 4, iPad Mini 3 modelinin yenisidir.
97 Soru Tümünü görüntüle
Physically hack-proofing 9.7" and mini iPads
Many organisations with security concerns are sourcing modified wifi-only iPads which can be utilised in high security environments. This requires removing the cameras and microphone. What would be involved in this mod on both mini 4 and ipad 6 models? How long would it take and what tools would be required?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
On the iPad mini 4, just open it up :>). Everything you want to remove is at the top end of the device, the two cameras and the two microphones (just look for the pin holes in the top right corner to locate them). The same would apply to the iPad 6 although the internals are slightly different. Check out the various guides here.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
You can set restrictions to disable camera and microphone - but users can re-enable by resetting all settings.
To make them permanently disabled, you need to physically remove them per Minho’s comment.
Puan 1
Yorum Ekle
Yanıtını ekle
Mark Taylor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 101
