flood of water from bottom of machine
what would cause water to flood out of bottom of my machine
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Hi @bear10 ,
Have you checked under the machine to see where the water is coming from?
It may be a cracked hose from the the water drain pump for example.
What is the full model number of the washer?
Bu yanıt yardımcı oldu mu?
I have a Kenmore 600 series top loader. We had a problem with rodents in the house and they started to chew the drain hoses which caused the same problem. There are two hoses - one short one that goes from the bottom of the fill basin to the pump and the other goes from the pump to wherever your laundry water empties.
These hoses should always have a little water in them since they'll never fully drain.
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 574
1 Yorum
My washer is model 110.44422610
And I'm having the same problem.
Hez tarafından
