Ana içeriğe geç
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
86 Soru Tümünü görüntüle
LCD and glass replacement question
In the process of replacing my LCD/Digitizer. I have ordered one on line and while watching a video the guy showed switching over the “open sensor”. My new LCD has a spot for this, but my old pad does not seem to have one to switch over. will this be an issue? Also, I have to replace the home button. The video mentioned having the security reprogrammed. will the new button work as a home button with the programming?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
For the sensor, if you have an original iPad screen, it should include the sensor. If you replaced the screen in the past, by yourself or by a shop, it is possible that it wasn’t transferred over as it requires some soldering. Ideally it should be there but it’s not a big deal, it’s mainly for detecting a smart cover that should turn off the screen when closed.
As for the Home Button, if you transfer over the original button, then it will retain everything. You have to be careful not to damage it while transferring otherwise you will lose Touch ID if you have to put a replacement button in its place.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
I damaged the original button. I have never used the touch ID. Only used as a home button. Ordered a new one. Waiting for it but now concerned it wont work.
tarafından
Yorum Ekle
There is no reason an aftermarket home button will not work on it. You just have to be careful not to damage it while installing. I’ve gotten a lot of defective home buttons at the shop I work at that didn’t work out of the package.
Puan 0
Yorum Ekle
Yanıtını ekle
Doug sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 889
