Ana içeriğe geç
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116 Soru Tümünü görüntüle
Soru Kapandı
Electrical issue with my 1990 300D
I have a 1990 Mercedes Benz 300d turbo diesel. Problem started with glow plug light coming on and off. I replaced the glow plug module twice so far and it appears to work for a while and then the problem comes back. maybe some kind of electrical issue. I am on my 2nd alternator. While the engine is running the glow plugs will come on at times and also a brand new alternator is putting out low voltage. Any ideas of what the issue might be or where to start looking?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Definitely a short or failed connection. First, check the 80 Amp strip fuse located in a black box on the firewall, left (driver’s) side. ANYthing less than perfect, REPLACE it. If that’s not the problem, CLOSELY inspect ALL connections between the ignition switch, battery, alternator, voltage regulator, and fusebox. Also, make certain you have updated all other fuses, to prevent future electrical issues.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
You must first understand how the controller works, initially its a timer circuit, do you allow it to fully run before trying to start the engine, not only the dash light to go out but the relay to completely cycle off by itself before trying to start the engine. Also pay attention until you replace it or find an additional problem, are you hitting a good size bump in the road for the light to come back on? Bouncing the relay box around may jolt the contacts together where they may stick together, under normal conditions, there should be no power for the short circuit to happen anyways. If you try to start again after the initial timed circuit has completed and the unit has a fault, it will come back on when it should not, this is where you inspect for ignition switch problems while driving down the road, do not hang a lot of keys from the ignition switch, the extra weight is a switch killer over time.
You may elect to upgrade to a manual system available online.
Puan 0
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 110
