Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
Restore successful but boot loop
Hello.
So i get this iPhone 7 on my desk, with water damage, very light corrosion here and there, cleaned and replaced the caps who seemed damaged, now the phone charges normaly (~1A on a 1A charger).
The iPhone turns on and after ~5 second resets itself, so i thought i might be the iOS that is the problem, so i restored with iTunes to latest version, all went well no errors the screen was lit the entire time with the Apple logo and the progress bar. After the restore finished, the iPhone went down and turned back on, but still the boot loop after ~5 seconds.
I repalaced/rebaled the Tristar and Audio IC’s also measured all the relevant main voltages. Also tried to turn on the phone without all the flexes… still boot loop.
Any hints?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Short boot-loop is usually BB related but with a water damaged phone, who knows, it could be anything. did you remove the shields when you did the decontamination?
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I removed the shields and cleaned everything but no corrosion what so ever. If it where a BB related problem would it not trigger a restore error? I had this kind of a problem before with a iPhone 7 where the problem was a defective/water damaged proxy flex...
tarafından
I agree, BB issues should give an error code during restore but when faced with no answers, you have to try something :>).
tarafından
Yorum Ekle
Hello, did you solve problem? I have same issue, little corrosion, bootloop, when i resolder audio with jumper does not help :) yeah and restore without error
Puan 0
Yorum Ekle
Yanıtını ekle
Dacian Bujor sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 263
