Ana içeriğe geç
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 Soru Tümünü görüntüle
E106 error after reset
I already did the sync and eject menu to factory reset my Xbox. It registered the reset request but now Everytime it tries to carry out the reset it says error e106 and I'm stuck in an endless loop where my Xbox won't reset itself please help. Any answers are appreciated
Bu iyi bir soru mu?
Puan 8
5 Yorum
Had the same problem, I've tried everything. What worked was a new harddrive, all e106 errors relate to your harddrive. You can find a tb one for abt 50$. If you have the proper screwdriver, anybody with a brain can get into Xbox and replace it, just takes some time. Just unplug your last one and plug in the new one. When you power on your xbox it will act as brand new. All of your game info is saved in the cloud, you'll just need to reinstall your games. A repair place will charge you 150$, not good.
tarafından
Which hardrive do I get
tarafından
I got the Seagate BarraCuda 2.5" ST1000LM048 - 1 TB - 2,5" - 5400 rpm - SATA-600 - 128 MB cache
tarafından
Same issue for the last two days thank you guys
tarafından
I repaired a console where the error 106 was a faulty hdd cable, hard to get for the Xb1s too:(
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Solution 1. Clear the cache
Xbox One error code e106 is a system error caused by data cache.  Please turn off your device and unplug. Allow it to remained unplugged for one minute so the cache will be flushed from the memory. Then to make sure it works, use Clear System Cache function. Please see below.
  1. Press the Guide button on your controller.
  2. Go to Settings Tab, select System Settings ==> Select Storage.
  3. Select any of the listed storage device press Y on the controller.
  4. Select Clear System Cache.
  5. When prompted for a confirmation, select Yes.
  6. Solution 2. Reset your console
  7. An unsuccessful update on your Xbox could cause error e106. To resolve this problem, please reset your console.
    1. Turn off your Xbox One.
    2. Unplug it for at least 30 seconds.
    3. Plug it back, then press and hold Bind button (located on the left side of the Xbox One) and the Ejectbutton.
    4. Then, power on the console without releasing the Bind and Eject button.
    5.  Release the Bind and Eject button after two power-up beep sounds.
    6. After that, you should enter the Xbox Startup Troubleshooter.
  1. Then select the Reset this Xbox using the controller.
Bu yanıt yardımcı oldu mu?
Puan 8
10 Yorum:
Streetsamurai11, if mayer's answer here doesn't work then make a startup repair flashdrive from here: https://support.xbox.com/en-US/xbox-one/...
Last resort scenario, use these guides to remove the HDD and re-install the filesystems and OS: Xbox One Hard Drive Replacement
use ONLY this video for proper re-install:
https://www.youtube.com/watch?v=GaKVBo3k...
Make sure and follow EXACTLY.
tarafından
Doesn't work, been stuck ok e106, I've tried everything that's been suggested by every video I could find.
tarafından
Mayer's answer can't work I have it to but you can't get out of the screen to go to
tarafından
i am still stuck in an endless loop where it shows me "preparing your console" and gets to about 4 percent and gives the error again.
tarafından
This is happening to me too. Is there any chance you already fixed the issue and tell me how to solve it?
tarafından
5 tane daha yorum göster
Yorum Ekle
I had the same issue and somehow got it working again. When initially turning on the gaming console and the update screen came on I repeatedly tapped the A button and the process went through. The box updated its self and came on. Hope this works for you as well. Good luck. @madbomberz242
Puan 4
4 Yorum:
Thanks, it worked for me. Struggled two years with E106 code, but after your suggetion with pussing the A botton, it worked. Now after two years, I can use my Xbox One again.
tarafından
Same here, thanks so much!
tarafından
Do you have to tap A untill the process is done?
tarafından
Doesn’t work
tarafından
Yorum Ekle
Turn off your Xbox One. Unplug it for at least 30 seconds. Plug it back, then press and hold Bind button (located on the left side of the Xbox One) and the Ejectbutton. Then, power on the console without releasing the Bind and Eject button
Regards,
Will
Puan 1
2 Yorum:
My Xbox is stuck on preparing console....it just stays at 1%. I keep pressing a and it changed to update 1 of 3 then switched off..HELP PLZ
tarafından
my xbox is stuck on restart this xbox but when i press restart it do not work it keep switching off..PLZ HELP
tarafından
Yorum Ekle
The A button trick worked for me as well. I think the console goes in to low power or sleep mode which disturbs the update and causes the error. By tapping the A button it keeps the console awake
Puan 0
1 Yorum:
Hi!
I don't understand how am i supposed to do it, when the xbox turns on i just spam the A button?
The update you are talking about is the osu1 from the usb ?
tarafından
Yorum Ekle
anyone who can help me with the 102 error system update i’m from south africa -email yenidrinkinghenny@gmail.com
please help 🙏
Puan 0
Yorum Ekle
Yanıtını ekle
streetsamurai11 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 77
Son 30 gün: 394
Her zaman: 121,192
