Ana içeriğe geç
4 Kasım 2017'de satışa sunulmuştur. Model A1865, A1901. GSM ya da CDMA olarak 64 ya da 256 GB kapasitelerinde, Gümüş ya da Uzay Grisi renklerinde satılır. ("iPhone 10" olarak da telaffuz edilir.)
Screw Map For iPhone X
Guys, I have searched the internet for hours trying to find a screw map that shows what size screws go into what holes for an iphone X. I need them all as the phone has been torn down to the bare case.. One of my kids got into my office and knocked my screws and associated drawing onto the floor and now I am screwed (pun intended). Any help would be greatly appreciated
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
There’s no screw map that I’m aware of. You ‘ll need to go through the guides on this page to find most but not all of them. The critical ones are those that screw into standoffs on the logic board. You must use the proper screws for those. You can also look at the iPhone 7/8 series guides if there are some areas that are not covered by the iPhone X guides.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Thanks for the help. I got the three Stand Off screws covered although the one next to the Tactic Engine wont screw in for some reason. and I have seperated the Tri Point screws from the PH screws. My big concern is the lengths of the screws. I guess I will just guess and not screw down too hard when I am putting in the long ones, And to anybody reading this, I strongly advise you to put the double sided tape onto your drawing and stick the screws down because this is a major pain in the ass !!!
tarafından
I have the same problem. Have you found any solution?
tarafından
Yorum Ekle
great,thank you very much.
Puan 0
1 Yorum:
I wrote the rear case replacement guide and in the process I followed the example of the guides that had already been written and measured the screws I removed and entered that information in the guide.
In most cases you should do fairly well finding a screw that matches the head style and length as indicated in the guide.
tarafından
Yorum Ekle
Yanıtını ekle
Sean Wren sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 77
Her zaman: 6,614
