Hi @thenewelite
The problem may not be in the acoustimass, it could be in the media console or even the cable connecting the two.
Even though the other speakers work when connected to the console this doesn’t mean that the audio signals are being sent to or are being received by the acoustimass, if you get my drift.
Hearing a hissing sound at least proves that the power/amplifier section of the acoustimass may be OK.
On p.37 in the Troubleshooting guide (see link below) it details how to make a base module (acoustimass?) test wiring cable so that it can be tested to see if it is OK or not. At least by doing this you can prove where the problem is located.
Here’s a link to the troubleshooting guide for the system.
To download the file, when the sentence below the Document preview box changes from This file is downloadable free, of charge: ...processing... to This file is downloadable free of charge: Download, click on Download. Be patient it takes a little while to find the file.
Hopefully this is of some help.
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
İptal
Bu yoruma uygun yeri bulmak için bu konuyu kaydırın. Ardından, taşımak için "Bu yazıya yorum ekle"ye tıklayın.
2 Yorum
Hi @thenewelite ,
What signal sources did you try, radio, DVD, external etc. Did you try all of them to hear if any worked?
jayeff tarafından
Hi @jayeff ,
I used CD, aux input (from two different sources) and FM radio. I have a spare set of speakers as well as cables of which I tried both, so I'm assuming the problem lies somewhere within the acoustimass module. All of the above ended with the same hissing and no output to speakers
Brant A. tarafından
