Turns off when power is unplugged + Not charging
I have a MacBook Pro that is having some sort of power issue - i’m not sure if its battery or board.
Its an older computer so I had the battery replaced at a locate repair shop, the new battery was put in and Coconut Battery stated it has 98% of its capacity available. a week I noticed the computer can’t turn on, so I plugged it in to charge and it turned right on, the charge light went to orange and the battery indicator said 100% charged - so I unplugged it and the computer turned off immediately. I plugged the computer back in and it turned back on, so I started using it while plugged in; within 30 seconds the screen faded off and the light indicated it was asleep. This was odd, so I pressed the power button and it turned back on - It woke up right away, only for it to sleep 30 seconds after.
I left the computer for a few hours to see if it will charge, and the indicator stays orange.
When I booted it, I checked coconut battery and it still says no battery fault, it reads the mAh that the battery has and it says the cycle count is at 7 currently (which is about right)
any help would be appreciated.
Bu iyi bir soru mu?
Did you have a liquid spill into the keyboard and/or trackpad, or sit the system down on a wet surface?
Dan tarafından
Nope never! I babied this laptop, the only problem is the track pad got a crack in when the old battery went out. However didn’t effect it...it still works as if the crack isn’t even there
D M tarafından
