Ana içeriğe geç
Device is write locked and unable to boot anything
Hello everyone.
I appreciate when you spend time in my topic and help me solve this problem!.
My MBP could not boot anything ( Internet recovery, CMD R, CMD V, shift…)
I tried install fresh copy of high sierra but just grey screen with nothing on it?
I did try single mode user then I got the screen like this
Can you help me with this problem.
Bu iyi bir soru mu?
Puan 1
6 Yorum
What is your drive a HDD or SSD?
tarafından
What happens when you boot up under an external bootable drive?
tarafından
Its finished the loading line then white screen of death
tarafından
I have ssd and hdd
tarafından
Have you tried to disconnect the hard drive cable and reconnect it?
tarafından
1 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
This most likely happened when you upgraded to High Sierra. The problem is most likely with your SSD as Apple doesn’t like you doing 3rd party upgrades and has tried to imposed APFS formatting to the SSD drive.
I would pull that drive reformat it GUID and only take the machine as high as Sierra.
Bu yanıt yardımcı oldu mu?
Puan 4
4 Yorum:
Another victim of APFS....
tarafından
The issue is more of which OS you use to boot the system. Here as its High Sierra you need to have the external boot drive also be high Sierra as the Disk Utility of High Sierra is needed to fix the drive. Using anything else won't work with a APFS volume. Thats assuming the boot drive is the SSD and was converted to APFS during the upgrade (most likely!)
The other possibility is the systems firmware did not get upgraded to the High Sierra update. This can happen when the drive was swapped from a different system.
tarafından
Thank you for ur answer. I got this. I cannot do anything, only white screen, how can i go to disk Utility to change my SSd and HDD or clear everything?. My mAc wont boot to that section...
I am only using single mode user, any command line to help me?
Again, thank you very much
tarafından
Hey there. Did you fix it? I'm in the same situation. Thanks
tarafından
Yorum Ekle
Yanıtını ekle
HaiPhan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 7,902
