Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
MacBook kernel panic reboots
Wondering if there’s a quick fix or a workaround
Crash Report
Bu iyi bir soru mu?
Puan 0
2 Yorum
Hi dan I have a early 2013 MacBook rentina dual graphics
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Found my workaround this fixed my issue to all who reads this this helped me out it disables the bad graphic card
http://dosdude1.com/gpudisable/
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
What happens when you boot up in Target Disk Mode? Restart your system and hold the T key, do you get the Thunderbolt Icon on your internal display?
If yes, try booting up in Safe Mode holding the Shift key what happens then?
Lastly, lets run diagnostics holding the D key when you restart. Did you get an error?
What I’m trying to do here is to locate what is failing as the crash report error is not very clear. If you can post the original text file instead of the JPEG snapshots so its more readable.
Reference: Mac startup key combinations
Puan 1
2 Yorum:
Ok thank you for the response well I added the text file up in the original post
tarafından
panic(cpu 0 caller 0xffffff7faccc5705): "GPU Panic: mux-regs 3 0 a0 d9 9 8 severity 3 - - - - AppleMuxControl/kext/GPUPanic.cpp:149
tarafından
Yorum Ekle
Yanıtını ekle
tyguy764 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 2,080
