Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
2690 Soru Tümünü görüntüle
iPhone 6s NAND flash IC missing/broken pad
Hi,
After I reballed by iPhone 6s nand ic using stencil, I broke one pad(3rd row from top). Can someone tell me whether that pad matters or not? You can see the photo:
Front Image and Back Image(IC flipped towards left )
Here is the NAND IC diagram from REWA technology:
Can you please compare the IC pads with those in the image to confirm whether it’s okay to proceed with this IC.
Thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
That’s a ground pin, it should be fine even without it.
Bu yanıt yardımcı oldu mu?
Puan 2
11 Yorum:
Thanks for the answer. I will solder it and see how it goes. I can see on the schematics these pads are shown as red and white/greyish dots. Are white dots ground or red ones are ground?
tarafından
@xoheyb I can't tell for sure, it depends on the color attributes one decides to use on his boardview sotware. I'd be inclined to think white is for ground and red for active pads.
tarafından
@arbaman I have added a photo and edited my question for more information. Can you please have a look? Thanks
tarafından
@xoheyb That's correct of course, white is ground and grey unconnected. Remember the direction of the chip, your picture is upside down when compared to boardview.
tarafından
Thanks for your reply @arbaman. Okay so the broken pad on the IC i posted is one for those grey coloured pads in bottom portion of the IC schematic right? And I can use this IC without any fear of damage caused by broken pad. I was actually comparing the broken pad(5th pad on 4th row from top) to the same top row on the schematic and was confused as there is a red pad. So it’s upside down.
tarafından
6 tane daha yorum göster
Yorum Ekle
Yanıtını ekle
Xoh Eyb sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 1,488
