Ana içeriğe geç
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
101 Soru Tümünü görüntüle
Replacement digitizer has rigid flex cable not allowing seating
Replaced cracked digitizer only, not LDC. All went fine and works prior to adhesion. But when I try to seat the digitizer on the frame where the ribbon cable reaches onto the board, the ribbon cables are so rigid I cannot seat the digitizer.
The cabling looks different than my original and part of it has adhesive tape, but I cannot tell where it should be stuck??? I thought the rear of the LCD but it pivots Portrait and the digitizer pivots landscape, so I wouldn’t be able to connect the cables.
Here you can see it in the second picture: https://t-depot.com/ipad-2017-a1822-a182...
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here is a picture of how the flex is supposed to be “taped” back to the digitizer prior to installation:
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
This won't bend it back and tear the ribbon then?
Super... thanks for the answer
-Cheers
tarafından
Yorum Ekle
Yanıtını ekle
David sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 59
