Ana içeriğe geç
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
577 Soru Tümünü görüntüle
tristar compatibility ipad air and iPhone 7 plus
H Everyone
Is 610A3B is suitable for ipad air??
I check the website where is tristar compatibility chart…
But i want a confirmation plz..
@refectio Sir i m tagging u :)
Thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum
@jessabethany Do you know the answer, Mrs. Microsolderer?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I personally have used the 610a3b in place of all other versions of tristar and have not had any issues. As long as the replacement Tristar is from the same or more recent version, you should be fine. Just don’t use an older version on a newer device.
I was scolded in the past from using the 610a3b in place of the 1610a1, a2, a3… but never had a problem from it :)
But would always recommend using the original where available. I have done 2 of the Ipad Air over the last couple weeks and both times, changing Tristar would get it to charge while on but not while off or sleeping. Had to replace the PMIC to get it fully charging properly
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
@teetopp Thanks a lot Michael... :))
tarafından
You are welcome, Anytime :)
tarafından
Welcome back!
tarafından
Yorum Ekle
Yes. The “tristar compatibility chart” is completely wrong. Use 610a3b for all 1610 variants.
Puan 0
1 Yorum:
@jessabethany thanks a lot
tarafından
Yorum Ekle
Yanıtını ekle
AGS sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,107
