Ana içeriğe geç
Touch ID + Flex Plate connector ripped
I was replacing a broken screen on my iPhone 6 Plus and I ripped the connector out from the flex cable that is built into the metal plate that come accross the screen. My question is if I replace the metal plate with built in flex cable, will my Touch ID work? The home button seems fine.
Thanks a lot
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
As long as you didn’t damage the HB, then it will be fine with a replacement heat shield/Link flex.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yes, as long as your home button isn't damaged - you can just replace the back plate with a new home button flex
Puan 1
2 Yorum:
@retechmobile If you agree with Minho or think his answer is helpful you can just hit the helpful button instead of reposting what he said...
tarafından
Ok, my bad. Thank you for pointing out that option
tarafından
Yorum Ekle
Yanıtını ekle
Fernando sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 80
