Ana içeriğe geç
The HP Pavilion 15.6” inch screen laptop with clear audio, a powerful 5th generation Intel Core processor and a sleek, stylish design. This laptop is exceptional for web browsing, word processing, and other simple programs. It is identified by the following model number: 15-ab165us.
How do I replace the battery charging port?
Some background: my laptop won't turn on whatsoever, no power indicator lights, charging lights, nor fans turning on. The device will not turn on or retain a charge.
I would like to know how to replace the battery charging port on my laptop. I had a free diagnostic done and they said that the port was physically damaged. They were not able to test if the laptop would turn on with a good battery because they didn't have an extra. Is there a way to use a multimeter to test the physical battery? How do you recommend I go about fixing the laptop?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
To replace the charge port on your model, it would take a little bit of work on your end, but it’s doable. Youll need to open your laptop to replace the port. Luckily the port is a cable that connects to your motherboard, so there is no soldering that needs to take place. If you are uncomfortable taking your laptop apart, I would take it back to the shop you went to.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
airforcepilot115 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 679
