Paper feed processing problem
My HP Laser Jet 1012 printer successfully prints a page, but will not feed through the printer entirely and a second page becomes jammed in the feed mechanism
Bu iyi bir soru mu?
Bu iyi bir soru mu?
I believe there are maintenance kits for these models which are usually expensive, but more times than not it’s the pickup roller. Try another toner as well. I have seen in certain printer models where the toner can cause jams.
Bu yanıt yardımcı oldu mu?
The User Manual (which you can get online) recommends:
In the meantime, a temporary solution is to stand by the printer while it prints and manually load one page at a time.
I replaced pickup roller $25 and still have same problem. Now thinking it's sensors, in which case, probably bye-bye printer. Otherwise, this printer has been the best tech investment ever in terms of stability, function and reliability, so missing in other gear.
Son 24 Saat: 2
Son 7 gün: 20
Son 30 gün: 79
Her zaman: 2,086
1 Yorum
I was having the same problem and the iFixit diagnosis, i.e., that there was a problem with the pickup roller was correct! Here is a guide to cleaning or replacing your pickup roller from the HP web site: https://support.hp.com/us-en/document/c0.... My problem was solved just by removing and cleaning it.
Johannah Rodgers tarafından
