Ana içeriğe geç
Laser printer made by HP. Uses the 12A toner cartridge, which produces 2,000 pages at 5% coverage. Rated at 15 PPM.
7 Soru Tümünü görüntüle
Paper feed processing problem
My HP Laser Jet 1012 printer successfully prints a page, but will not feed through the printer entirely and a second page becomes jammed in the feed mechanism
Bu iyi bir soru mu?
Puan 1
1 Yorum
I was having the same problem and the iFixit diagnosis, i.e., that there was a problem with the pickup roller was correct! Here is a guide to cleaning or replacing your pickup roller from the HP web site: https://support.hp.com/us-en/document/c0.... My problem was solved just by removing and cleaning it.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I believe there are maintenance kits for these models which are usually expensive, but more times than not it’s the pickup roller. Try another toner as well. I have seen in certain printer models where the toner can cause jams.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
The User Manual (which you can get online) recommends:
  • Cleaning the pickup roller with a lint-free cloth and rubbing alcohol. Just tried that and it enabled my printer to grab 3 pages one after the other (instead of jamming after just one).
  • Alternatively, replacing the pickup roller. I see you can order some on Ali Express. Haven't tried that yet.
In the meantime, a temporary solution is to stand by the printer while it prints and manually load one page at a time.
Puan 0
1 Yorum:
I replaced pickup roller $25 and still have same problem. Now thinking it's sensors, in which case, probably bye-bye printer. Otherwise, this printer has been the best tech investment ever in terms of stability, function and reliability, so missing in other gear.
tarafından
Yorum Ekle
Yanıtını ekle
Ellen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 23
Son 30 gün: 74
Her zaman: 2,079
