Ana içeriğe geç
Arayan kimliği özellikli Uniden D1760-2 DECT 6.0 kablosuz ev telefonu.
Flashing light on handset
The red light on all handsets is flashing and there is a rapid beep as dial tone. Can still ring out and receive calls . We dont have telstra message bank activated
Bu iyi bir soru mu?
Puan 1
2 Yorum
where is the find button
tarafından Paylaş
@rhondapollard
Please confirm the model number of your phone?
tarafından Paylaş
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @tina51 ,
What is the model number of your phone?
If it is a Uniden Dect 1760 to turn off the light:
With the phone in standby, open the menu and select Global Setup; select VMWI Reset, then select Yes.
Is the phone connected as a VOIP phone service on the NBN?
If it is then are you sure that Messagebank hasn’t been turned On? By default Telstra turns on Messagebank when on the NBN.
What do you get when you dial 101?
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Thanks so much. Going to global set up fixed it . Yay. Thanks for thatt
tarafından Paylaş
dect 6,0 uniden
tarafından Paylaş
@barbaraejones
Unfortunately that's not the model number. It's the signalling protocol used by the phone.
The model number can be found on the bottom of the base station or sometimes under the battery in the phone
tarafından Paylaş
Yorum Ekle
En Yararlı Yanıt
Press and hold the FIND button about five to ten seconds until the beeping stops.
You can also try clearing all incoming calls.
Puan 3
1 Yorum:
there is no FIND button on the menu?????
tarafından Paylaş
Yorum Ekle
How do I delete messages...and stop the explitive phone from continuously from flashing?????
Puan 0
Yorum Ekle
Yanıtını ekle
Bettina Slocombe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 88
Her zaman: 27,676
