Loose Crank and grinding bearings.
I have a Schwinn 26” Frontier with a loose crank. I tried tightening it and the crank is still loose but now my bearings make a loud squealing sound every five or six turns. How do I fix it?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
What exactly did you tighten? The crank bolt that fastens the crank to the axle?
Or, the bottom bracket itself?
Is the crank loose, or is it the bottom bracket?
Isolate the exact problem first before proceeding.
Did you remove the crank and tighten the bottom bracket?
If you attempted to tighten the bottom bracket (BB) and it is still loose and noisy, it needs to be replaced.
Plan on spending about $40 for a replacement.
If, you tried to tighten the crank with the single crank bolt, and it is still loose, the inner faces are probably worn so they are no longer square. The crank therefore needs to be replaced.
An experienced mechanic can certainly help you diagnose the problem and offer you advice.
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 303
