Purchased fixit LCD need to remove frame
Purchased a iFixit LCD for the iMac EMC 2389. It does not come with the two frames on each side with the magnets. How do I remove the old one and install on the new screen?
I looked at the LCD cleanup, but that doesn't fit the model.
Need ya help on this.
Bu iyi bir soru mu?
4 Yorum
Lets verify your system plug in your serial number (on the bottom of the foot stand) here: EveryMac - Lookup Paste the system info here for us to see and also tell us the part info you ordered (received) so we can make sure you get the correct part.
Dan tarafından
Apple iMac "Core i3" 3.06 21.5-Inch (Mid-2010) Specs
Identifiers: Mid-2010 - MC508LL/A - iMac11,2 - A1311 - 2389
Part I ordered:
Part # IF173-041-2iMac Intel 21.5" EMC 2389 LCD Assembly / New
kneisley tarafından
Well, you did get the correct part!
Once you get the frame off your old panel and installed to the new panel you should be OK.
Dan tarafından
That's the whole problem of getting the old frame off. I got the two on each side off, but where are the others?
kneisley tarafından
