Ana içeriğe geç
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
86 Soru Tümünü görüntüle
Screen is black after repair
My screen is not functioning after repairs.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
It’s very important to always isolate the battery before disconnecting/reconnecting the screen assembly. The issue is that the LCD connector has pins that have high voltages (i.e. the backlight is ~20V) and ground in very close proximity. When you fumble around trying to line up the connector plug to the receptacle, you can short out the voltage rail and cause damage to the components in the backlight circuit. If you’re lucky, then only a backlight filter is damaged but other times, the entire circuit could be affected. Either way, this type of repair requires micro-soldering and isn’t really a DIY repair.
To test for this, plug your device into a charger or an iTunes enabled computer. Then shine a bright flashlight on the screen. If you can see a dim image, then the backlight circuit has been damaged. If you can’t see an image at all, then it may be the LCD circuit that is damaged.
If iTunes doesn’t recognized the device than the problem is more than just a screen or backlight issue.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I think that’s exactly what happened, thank you.
tarafından
So the if there is no picture on the screen then all of the connectors for the screen on the logic board need to be replaced, am I correct?
tarafından
Yorum Ekle
Hi Nick,
Closely inspect all the LCD Connectors to make sure they are correctly plugged in.
Otherwise it may be your LCD Display chip.
Try inspecting all connections inside the iPad making sure they are all correctly plugged in and mounted down properly and let me know.
Puan 0
Yorum Ekle
Yanıtını ekle
Nick Ehlers sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 116
