Ana içeriğe geç
İkinci nesil (KK) Jeep Liberty, orijinal Jeep tarzının klasik keskin hatlarını geri getiren, kompakt 4 kapılı bir SUV'dir.
Where is the actuator located
I need to replace my blend door actuator so my heat will work. Ive asked mechanics and the all tell me that the dash has to be removed but youtube tells me its on the driver side and can be replaced with out removing dash..please tell me this is true
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
heater blowing cold air
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
The actuator that controls heat/cooling is located in the area just above the driver's right foot. To access, pull down the panel below the steering wheel, then slide it to the left. It will come off. Then you can see the actuator. There are two. The lower actuator controls the heat/cooling. It has two t20 screws. Very easy to access, remove, replace. The upper actuator controls the direction of airflow (feet, face, defrost). It's upper screw is more difficult to access.
Puan 4
1 Yorum:
Pls the circulation and A/c light is not coming up in my liberty Jeep 2008 what could be the problem
tarafından
Yorum Ekle
Yanıtını ekle
Joseph Schwager sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 28
Son 30 gün: 117
Her zaman: 7,907
