Ana içeriğe geç
Model A1224 / EMC 2316 / 2.26 GHz Core 2 Duo processor / Education only model. Released on March 4, 2010.
Upgrade OS to High Sierra?
I have upgraded to El Capitan, but would like to know if the model could be upgraded (clean install) to High Sierra or perhaps Sierra? According to the spec’s listed for the OS X High Sierra, this model should be able to be upgraded to High Sierra.
If it is not able to be upgraded, could you elaborate on why it would not be able too? Thanks
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The Core 2 Duo based systems are not able to run 64bit apps natively.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
En Yararlı Yanıt
High Sierra and Sierra both require a Late 2009 or newer model iMac. Yours is a Mid 2009 model so it cannot run either.
Puan 1
4 Yorum:
Slight correction The highest is El Capitan OS-X 10.11.x
iMac "Core 2 Duo" 2.26 20-Inch (Mid-2009)
tarafından
Oops. Edited.
tarafından
Is this a limitation of the processor? If a new SSD hard drive were to be installed, would that make a difference? Thanks!
tarafından
The CPU is the issue not storage. But! Putting in a SSD will improve performance! iMac Intel 20" EMC 2266 Hard Drive Replacement
I would also max the RAM to 8 GB. iMac Intel 20" EMC 2266 RAM Replacement
tarafından
Yorum Ekle
Yanıtını ekle
Rob sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 730
