Ana içeriğe geç
Repair guides and support for your Philips TV.
242 Soru Tümünü görüntüle
TV has bad horizontal lines and flickering image, help!
I recently was given a free Phillip's t.v. , model #: 55pfl5402/f7. I got it for free because the screen was flickering, but boy is it flickering. The whole screen flickers in and out with with black and white lines. Image is stable for maybe a second but not long. TV is a smart tv and connects to internet, loads up apps and everything. Seems like the only problem is the screen/lcd.
Could anyone point me in the right direction as far as what to check/fix?
Thank you!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Ashley Self  we really would need to see what it looks like. It could be an issue with the T-con board or the main board. See if you can post some images or short video about what this looks like. Adding images to an existing question
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Thank you! I tried to when I posted, but I couldn't find the option
tarafından
This could be a panel issue (bad gate drivers) as well. The large vertical lines are possibly a bad main/T-con board. This is going to be a tough one and I'd try a main board first
tarafından
Ashley, did you find the solution? I have the same problem. I don't want to buy multiple parts if you can guide me. Was the main board or t connector? Thanks!
tarafından
Yorum Ekle
Yanıtını ekle
Ashley Self sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 48
Her zaman: 6,757
