Ana içeriğe geç
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
Lighting jack is not working
My iPad Air 2 is not charging. I’ve tried restarting the device, cleaning out the lighting port, changing cords, chargers, and wall outlets to no avail. I was looking for other ideas as tot he cause, or for a replacement part to replace the defective part.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
Thank you all for the info. Much appreciated!
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Unfortunately, your port may be defective. It is soldered to the Logic Board and would require micro-soldering to be replaced. If you want to repair it, it may be cheaper to take it to Apple, as micro-soldering can be very expensive.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
You can buy a replacement charging dock voor the ipad air 2 it isnt that hard to repair no soldering needed , buy one with flex cable.
Puan 0
2 Yorum:
The charging port flex assembly is connected via soldering to the logic board. So it will require soldering to replace that charging port.
Good video on how it's done here: https://www.youtube.com/watch?v=IdyIQYrO...
tarafından
Alec and Ben , sorry you are right. For the normal ipad 2 it is easier and with a flex cable.
tarafından
Yorum Ekle
Yanıtını ekle
Ryan Lantz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 29
Her zaman: 428
