Ana içeriğe geç
The Asus Q551L is a 2 in 1 device released in 2014 by Asus. The screen is 15.6" and the device comes with a 2 GHz Intel Core i7 processor.
Screen hinge on left side not working
I dropped my computer and the hinge is not working right. I can close the laptop if I put enough force but the display does not line up correctly with the base of the computer. Also, I can put it in tablet mode, if I put enough force, but again the display does not line up correctly with the base. So I just keep the computer open. I have not opened it and the display and all other components still work but here are my questions:
Do I need to buy a new hinge?
Where can I find that sort of part?
What would be the best possible course of action?
Where can I find instructions on how to change the hinge?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @valxander ,
I suggest that you open up the laptop and check whether the problem is with the actual hinge or perhaps the hinge mount.
Here’s a link to the ifixit Asus Q551L guides which may be of some help to gain access so that you can inspect the left hinge, left hinge mounting area.
Here’s the part number for the left hinge : 13NB0691M07011
If you search online by typing the part number only in the search box of your browser, you’ll get results for suppliers of the part.
Here’s a link to just one supplier - (example only). It’s shown just to give you an idea of the cost of the part. There are other suppliers that may suit you better.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Thank you, I opened up the base and from the base the hinge looks fine. However I think the issue is on the mount inside the display panel, I can see the panel seams of the display panel buckle when I try to fold it in tablet mode.
tarafından
Hi @valxander ,
Here's the part number for the LCD cover: 90NB0581-R7A010
Unfortunately when searching for it using the part number only, most suppliers state not in stock no longer available.
You may have better luck in finding one if you decide that you cannot repair yours.
tarafından
Yorum Ekle
Yanıtını ekle
Alx V sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 855
