Ana içeriğe geç
6,01 inç AMOLED ekrana sahip bir Android akıllı telefon olan OnePlus 5T için onarım rehberleri ve destek. Kasım 2017'de piyasaya sürüldü. OnePlus 5'in devamı niteliğindedir. Model numarası: A5010.
Issues with screen after replacing
Hello,
I'm experiencing some issues after replacing my screen. I'm getting a lot of ghost touches when scrolling, and every few days the screen goes crazy with clicks. Completely unusable. Can't do anything but hard reboot which fixes it. The Keyboard is a bit off. Most gestures work, but only if you use a different one each time. Example: You can't use 'V' twice in a row. You have to do a different gesture each time or it won't respond. Music gestures don't work at all.
Everything else works as it should.
Any idea what could be causing it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Probably needs the digitizer cable reset. OnePlus 5T Teardown here is the tear down video if you feel like doing it yourself. The LCD able is around 3:43. If that doesn’t do it it is probably an issue with the motherboard connector or the LCD connector itself. My guess would be that it is not seated properly.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Original screen folder Amoled
Puan 0
Yorum Ekle
Yanıtını ekle
Liam Mooney sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 2,001
