Ana içeriğe geç
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Headlight won’t turn on
The passenger side headlight on my 2003 Nissan Altima won’t turn on. I changed the bulb twice, checked the fuse box under the hood and won’t turn on idk what’s wrong with it. Please help me
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
The following images are from the 2003 Altima Service manual (lighting system LT) showing how to check the low beam headlight circuit
(click on images to enlarge for better viewing)
The IPDM E/R means “intelligent power distribution module - engine room”.
If there is no power to the headlight connector and the ground check is OK and if the harness tests OK between the headlight connector and the IPDM E/R then there is a problem with the module and it needs to be replaced.
Here’s a link to the various sections in the manual which may be of some further help.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
dowellblake sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 1,032
