Ana içeriğe geç
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Soru Tümünü görüntüle
not charging and taking along time to boot to home screen
@refectio i have an issue with this iphone 6. when i got it, it wouldnt boot. on dc and charger with battery disconnected it took around 0.23 amps. i removed tristar and tried dc again and got apple logo. put a new tristar on and as soon as the amps reach around 0.83 the phone restarts. it now eventually boots to the home screen after a few minutes but it wont charge, not showing the lighting symbol in the battery and it stays at 1%. i have already changed tigris aswell, tried a different cable, battery and port. do you have any ideas
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hey Daniel. Did this phone just die out of the blue (the famous nightstand issue ;>) or was it dropped or came into contact with liquid?
You should probe around the charge circuit again looking for any anomalies. Specifically, check the SWI line (battery) and C1402/L1401 in the Tigris area. However, the fact that the phone takes a while to boot could be an indication that there is another issue at play here. Seeing as how you have already changed pretty much everything in the charge circuit, I would check out the PMIC and BBPMU outputs to see if another subsystem is causing any issues to the boot process.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
The pp3v3_acc cap above Tristar was short. All good now. Thanks for the advice tho
tarafından
@refectio I have a 6s here I replaced the lcd fpc on. Came on fine then I put it on charge and it was charging fine. Came back and stuck on apple logo. Replaced tristar and tigris and all nand voltages are normal. Any ideas
tarafından
Yorum Ekle
Good news and bad news Bad news i only have the answer to 1 of your problems. and that problem is the battery problem. My sister has this problem. All you need to do is change the battery
Puan 0
1 Yorum:
Was nothing to do with the battery there was a short on the board. Working now. But thanks
tarafından
Yorum Ekle
@refectio
Hi,
i have a similar problem with an iphone 6. I have a question for you. What do you mean by “check c1402 and l1401” ? I have 4.38v on one side of that coil and 3.88 on the other side. Please help me because I don’t know what do try anymore. Already replaced tigris, tristar, checked all the voltages nearby and they all seem fine.
Puan 0
Yorum Ekle
Yanıtını ekle
daniel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 94
