Ana içeriğe geç
Lehimleme, iki metal parçasını aralarına dolgu metali eriterek birleştirme yöntemidir. Birçok lehimleme türü vardır ancak bu makale, size temel elektriksel lehimlemeyi öğretmek için hazırlanmıştır.
Micro soldering start up
Hey all I am hoping there is someone out there who may be able to help me.
Recently I have been doing some research into micro soldering and would like to give it ago.
What equipment should i look at getting and what do I need to take into account.
Any advice would be great .
Thank you
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Jessa Jones created a set of vids with IFIXIT a few years ago which are very informative! Here’s the first in the series Microsoldering with Jessa Jones.
Theres a lot to it! Between getting the correct gear, you need the skills to read and understand schematics and lastly access to the needed SMT components.
And lastly practice! Lots of it!
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
Thank you very much for this very appreciated.
tarafından Paylaş
Yea .... Dan hit the correct word.... practice made perfect :D
tarafından Paylaş
Yorum Ekle
Hi claytonrablin
As for me, I had a Hot air SMD rework station and a temperature controlled soldering station.
Some would say for temperature controlled station, minimum 60W and above.
I prefer those stations to be separated, in event of a failure which will brick all usage. Encountered once when my temperature controlled soldering station heating element is bad. Lucky having the hot air, which is needed to solder the new heating element to the soldering iron.
Get good flux, desoldering pumps, etc.
A good start.. .Louis Rossmann videos...
https://www.youtube.com/watch?v=bVoBZqlv...
Update (01/20/2019)
Thankyou very much for this fantastic advice. What did you start off soldering ?
Update (01/20/2019)
Hi claytonrablin
Replacing QFP ethernet chip
Puan 4
Yorum Ekle
Yanıtını ekle
claytonrablin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 787
