Frigidaire FPRH19D7LF1 leaking water from the inside
My Frigidaire FPRH19D7LF1 is leaking water from the inside & it pools up below the bottom shelf, before dripping out onto the floor in front.
- What’s my problem?
- How do I fix it?
- Thanks
Bu iyi bir soru mu?
3 Yorum
I have the exact same refrigerator w/ exact same issue (also sold as an Electrolux, made by them I believe)
Dane Kantner tarafından Paylaş
Just got my fridge a week ago. When I hooked up the water supply line and went to dispense some water instead of coming out of the dispenser it was running on to my floor from the bottom left corner of the door. Has anyone else ever had this problem and how do I fix it
Jeremy P Russell tarafından Paylaş
@jeremyprussell
What is the full model number of the refrigerator?
If the refrigerator is still covered by the manufacturer's warranty, contact the manufacturer's service centre in your location to get them to fix it so as to not void the warranty by trying to fix it yourself.
If it's no longer under warranty it sounds like the hose connection between the main water inlet solenoid valve and the dispenser valve has come adrift somehow.
As I said above knowing the model number will help
jayeff tarafından Paylaş
