Ana içeriğe geç
Braun tıraş makineleri için onarım rehberleri.
Razor not turn on
Cruzer5 charges but does not turn on
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @tamandy239 ,
Does it turn on when the charger is connected and switched on?
If it does then the batteries may be failing to hold their charge and need to be replaced.
If it doesn’t then there may be a problem with the on/off switch etc.
In any event the razor will need to be opened and inspected as to what the problem may be.
Here’s a link to a video that shows how to dis-assemble the razor.
Hopefully this is of some help.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
The video is private, I can't view it.
tarafından Paylaş
@ハッサンモハメド
Try this one
tarafından Paylaş
Yorum Ekle
Make sure the razor is charging correctly. It is a common mistake to see the solid green light on the charger, but it also requires the flashing green light on the razor itself.
Puan 0
Yorum Ekle
Yanıtını ekle
Andy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 37
Son 30 gün: 136
Her zaman: 23,223
