Ana içeriğe geç
Why don’t my headphones work?
My MPOW Flame Bluetooth headphones aren’t working. I’ve tried connecting them, and it said out of range. Then, they stop working. I’ve put them on charge for several hours, and nothing’s changed. I press the “ON” button and I hear two beeps and the red/blue lights flicker for a second or two. They’ve been in my cabinet for a couple months and nothing on the internet has helped me. Any takers?
Bu iyi bir soru mu?
Puan 5
6 Yorum
My earbuds won't pause my music, and I don't know why. anyone know why?
tarafından
My earbuds automatically turns off if I they move suddenly. I charged them just to make sure they’re charged fully but even so it still turns off. Why and how is this happening?
tarafından
My earbuds suddenly stopped working. After giving them a full charge, then turn on and then immediately turn off without even connecting to bluetooth. Then aftera few tries, I got them to turn on and connect. Now they seem to be working..
tarafından
I just bought these I used them less than 5 minutes and the left side stopped working any suggestions?
tarafından
My headphones turned off randomly while fully charged and won't connect to my phone, I press the power button for four seconds and while saying power on it randomly stops in the middle and won't finish and when I did get the chance to connect it to my phone is said that my headphones rejected my device and I don't know where
tarafından
1 tane daha yorum göster
Yorum Ekle
7 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @gooby ,
When you charged them did the charging light go from red to blue to let you know that the battery was fully charged?
It may be that the battery if failing to hold its’ charge when under load or it has been depleted beyond recovery and has to be replaced.
Unfortunately, I cannot find any information online on how to replace the battery in your headphones.
There may be another solution for you to consider.
How old are the headphones?
According to this link there may be an 18 month manufacturer’s warranty on the headphones so you may wish to follow this up if your headphones aren’t that old.
Bu yanıt yardımcı oldu mu?
Puan 5
7 Yorum:
My mpow flame has a blue light when the charger is connected. But it won't come on or pair
tarafından
Did you ever figure out how to fix this?
tarafından
@nekishavincent did you ever find a solution mate?
tarafından
My own is having the same problem
tarafından
Same issue here, charges fine and when I take it off charge when blue light appears the headphones won't turn on.
tarafından
2 tane daha yorum göster
Yorum Ekle
Hi @Jean Riddle
If you just bought them, return them and get a replacement or a refund. They are faulty and should be covered by the manufacturer's warranty.
Puan 2
Yorum Ekle
It could be that the earphone cable has shorts. I realize every time i touch the cord on mine it turns off/disconnects from my laptop/phone. I have the MPow Flame 2
Puan 1
2 Yorum:
Even i have the same problem....did u happen to find a fix for that or is it just done for??
tarafından
Ya same here would be great if someone found out how to fix it
tarafından
Yorum Ekle
I have found that the wire connecting the battery (in the left ear piece) to the circuit (in the right ear piece) shorts out as said in other answers to fix this I have used J-B Weld to glue a piece of plastic on the base of the right ear piece letting it sit and getting a spring over the plastic piece and glueing that there has made it work fine
I think it's a fine fix if you aren't bothered by the gray glue on the right ear piece
Edit: that is if you for some reason you can't get a replacement or refund
Puan 0
Yorum Ekle
If all else fails, try a reset.
Mine are the mpow flame solo, and they randomly stopped playing audio from my phone.
The headphones were fine, the voice spoke to tell me they were turned on.
To reset: make sure they're not connected to whatever device you're connecting to.
Take them out of the charging box, make sure they're turned on, but not connected.
Hold down the +volume and - volume button at the same time and hold until the headphones turn off.
Turn them on and connect. Voila~
Puan 0
Yorum Ekle
I have MPOW M30. Both of the ear buds charge fine and follow all commands like pause, play, next, previous, volume max and min but my right bud is not playing any sound. I tried reset, charging them as well as turning them off and then on. Any fix for it?
Puan 0
1 Yorum:
I have the exact same thing. I don't hear the voice anymore either. First the right one stopped working and now the second one as well. Reset doesn't help either and it's not because of a faulty battery
tarafından
Yorum Ekle
I have a Mpow flame lite and only one headset has sound. Am I doing something wrong?
Puan 0
Yorum Ekle
Yanıtını ekle
SillyMcWilly sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 49
Son 30 gün: 239
Her zaman: 33,360
