uneven streaks on paper
Hi, I've been getting white streaks on my color copies that vary in width and tried several things.
1- cleaned the glass lens with a soft cloth.
2 - swiped a clean cloth across the fuser bristles.
3 -Reinstalled the driver.
4- purchased a new drum but the problem remains.
Suggestions?
I scanned a sheet illustrating the problem so it someone supplies a email address I'll forward the copy file. A picture is worth a thousand words. Thanks (bt97128@gmail.com)
Bu iyi bir soru mu?
2 Comments
When you say white streaks, do you mean vertical streaks where it looks like no toner was deposited? Are they constant width streaks or do they vary along their length or from sheet to sheet? Yes, a pic would be very helpful. You should be able to edit your question and upload it.
My first thought was that it sounds like the toner cartridge isn't depositing toner evenly across the width of the drum, but if black and all three colours are equally affected then that would almost certainly absolve the toner cartridges.
It's a while since I've attempted to clean a laser printer, but I think they normally have a wire held at a high voltage and running the width of the drum in order to charge it. You normally also have to clean that.
Philip Le Riche tarafından
Hi @bt0414 ,
Here's how you can add images to your question on ifxiit
Adding images to an existing question
jayeff tarafından
