Ana içeriğe geç
6th generation of Motorola's Moto G line. This phone was released in 2018 and features a glass back that is easier to remove than Samsung phones. Model numbers are XT1925-4, XT1925-5, XT1925-6, XT1925-12 and XT1925DL.
Phone wont power up
I dropped my phone and it was fine, until the next morning it wouldn't power up. But when I plug it in the blue indication light comes on. What could be wrong with my phone
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Try booting to recovery:
  1. Hold the Volume Up and Power buttons simultaneously for a few seconds.
  2. Release both the buttons once Fastboot mode appears on the screen.
  3. Now, use the Volume Up/Down button to navigate to Recovery Mode and press Power button to select it.
  4. Once the Android Robot screen appears, press and hold Volume Up and Power buttons.
  5. Now you should be in Recovery mode. Now, release the buttons.
If you can get in recovery, I would try wiping your cache partition (you use the volume buttons to navigate and power button to select). If it still doesn’t boot after wiping the cache, you might need to factory reset the phone (which you can also do in recovery).
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
I've tried this more a few times to no avail, I thank u for your help tho
tarafından
Yorum Ekle
If the power button is broken/unresponsive then obviously using it to try to reboot the phone is pointless. I also have this same issue. I can’t find any info anywhere about fixing or replacing the power button, DIY.
Either try to get it fixed somewhere or see how much Motorola charges. Otherwise, get another phone (NOT a Motorola!). I had my phone less than 6 months when it crashed and the power button hasn’t worked since. Motorola only has a 6 month warranty for this phone - now I know why.
Puan 0
Yorum Ekle
Yanıtını ekle
Landry sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 28
Her zaman: 1,165
