Ana içeriğe geç
Smart fitness watch via Bluetooth, released in March 2016. Model: FB502SBUL
Fitbit Blaze only works in charger
My Fitbit Blaze works fine in the charger but shuts off immediately if the charger is unplugged or the watch is taken out of the charger. Can’t even reset using the reset procedure from Fitbit as there is no power at all. Shows 100% when in the charger. Is the battery a realistic possibility? It can’t imagine it is but the alternative sucks.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi,
If it works on the charger but not when on the battery only, then most likely the battery has failed and needs to be replaced.
Here’s a link to the ifixit Fitbit Blaze Battery Replacement guide, which shows how to replace the battery.
ifixit sell a battery for the watch. Here’s a link Fitbit Blaze Battery
There are also other suppliers that may suit you better. Just search online for LSSP321830 to get results.
Replace a 170 mAh battery compatible with the Fitbit Blaze smartwatch. 3.7 Volts (V). Görseli
Ürün
$19.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Chris Chandler sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 5,556
