Ana içeriğe geç
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
20 Soru Tümünü görüntüle
If I replace my MacBook's housing will Apple refuse me service?
My Macbook Pro 2014 13” housing is in tough shape and I would like it to look presentable again. I fear replacing it, however, since the serial number on a replacement housing will no longer reflect the original one. If I ever bring it to an Apple Store for a free repair program or a recall in the future, could they deny me service, or worse, carry me off to the Apple Store backroom to be interrogated by the Apple Police?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
First Apple has a repair policy when the bottom cover is replaced. The servicer is required to note the original systems S/N on the inside of the lid in permanent marker. So I would recommend you do that so your system is following the SOP.
As for Apple refusing service a replaced bottom cover would not be a good enough reason. Liquid damage or a mangled mess after a car has run over your system a few times. Of course obvious altering or mis-assembled parts is a red light so take your time and make sure you don’t damage anything and put the correct screws back in where they came from. Any of these actions would stop Apple as well as me ;-}
Apple will do extended warranty service without question. Thats all you have now any ways.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Really?! You mean repairing the forbidden fruit will not necessarily condemn our machines to eternal damnation? So long as we repent to lord Jobs by confessing to the serial number inside the bottom cover, we'll be saved? This is a wonderful sermon. You need your own book, "The Gospel According to Dan."
tarafından
I'm not a plagiarist ;-}
tarafından
Yorum Ekle
En Yararlı Yanıt
You might consider a good hard case like this:
https://www.ebay.com/itm/Quicksand-Metal...
Puan 3
2 Yorum:
Thanks, but masking over dents and gouges takes away from the intended beauty of Apple's product.
tarafından
If it's still beautiful. Some are downright ugly after several years of abuse.
tarafından
Yorum Ekle
Yes. Apple will look for any and all excuses they can find to refuse service to you, and changing out the entire case will definitely be one of them.
That being said, the 2014 MacBook Pro is also ~5 years old now, and any defects that would warrant a recall would almost certainly have cropped up already. If the housing is the only issue with it and you feel comfortable changing it out, I’d say just go for it regardless.
Puan 2
1 Yorum:
Most likely denied service. Apple hates unauthorized tampering.
If this allows you to go in to the Apple Store backroom this easy, I would’ve tried this long time ago. I’m curious what’s in there and nobody non-Apple seems to be able to enter the back room.
tarafından
Yorum Ekle
Yanıtını ekle
AppleGuyPie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 710
