Erratic booting and at times does not reboot at all
My MacBook air is functioning erratically, did not see any water damage, how do I debug this?
Update (02/24/2019)
Bu iyi bir soru mu?
Puan
0
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 121
Your picture is not very sharp as such it doesn't offer anything useful on the logic board. The Top left cell looks a bit off but that maybe the lighting and blur.
Instead lets go through a proper diagnostic process. First lets check your battery by installing CoconutBattery post a snapshot of the main window here for us to see Adding images to an existing question.
Next, lets open the Console app (in Apps > Utilities folder) do you have any current crash reports? if you do safe it to a PDF and post it as well.
Dan tarafından
Hi Dan,
I am unable to log in. As I log in, it shuts down and any attempts to reboot results in no response. After a time lag and many retries, it will reboot and then immediately shut down. When it boots I see the battery at 36% and once I saw at 95% so there seems to be some battery charge left.
Karthik Krishnamoorthy tarafından
OK, lets try this, disconnect the battery hold the power button for a good 2 minutes, then plug in your MagSafe charger did that stabilize your systems rebooting?
Dan tarafından
I got it to boot once cleanly and was able to log in and then when I disconnected power it shut down and have not been to reboot it since.
I had to reconnect battery for now to close the lid. This is Mid 2012 MacBook Air 11” [I had wrongly selected as 2011]
I’m also hearing a lot of fan noise, which I could not hear before even though I have not been able to boot it after the one power reset.
Repeat the process and this time with the battery re-installed run this app CoconutBattery and get a snapshot of the apps main window and paste it here for us to see Adding images to an existing question. You'll want to have a USB drive ready with the app and so you can pull of the screenshot off.
Dan tarafından
5 tane daha yorum göster
