Ana içeriğe geç
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Soru Tümünü görüntüle
Random black screen...AHT shows 4MOT/40000003: HDD-1333
Have been experiencing random black screen upon waking the computer up from a longer period of sleep 10-12 hours. Screen initially lights and then goes black. Thought it may be the GPU (AMD Radeon 6970M 2gb) so ran the AHT to see if it came back with anything on it but instead got 4MOT/40000003: HDD-1333. From what I've found online this seems to be the hard drive fan behind the motherboard. This imac was special ordered with two drives, SSD with the OS on it and then a secondary HDD. Do you think replacing the fan will fix the black screen issue? Is there a fan for each hard drive in the computer or are they stacked in the same location? Thoughts on what this may be and possible fixes?
Bu iyi bir soru mu?
Puan 0
3 Yorum
Have you changed a hard drive?
tarafından
Nope. Factory SSD and HDD.
tarafından
Part of the problem is I'm not sure which drive would need replaced if one does, since there's two and AHT doesn't tell you much along those lines....
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
This model had major GPU issues and had a Apple repair program for replace it (of course, now expired). Hook it up to an external monitor to help isolate the issue. If the external exhibits to same issue, you will need to replace or repair (reflow) the GPU.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks! Yes I saw the repair program when googling the issue but as you said it's expired unless you're in new Zealand…found a new GPU off Mac parts depot…may try to open it up and replace that and the HDD fan at the same time and see if that doesn't fix it. Thanks!
tarafından
Yorum Ekle
check out my short video on the problems I had. it might help.
How to repair video on Mid 2011 27 inch iMac
Puan 1
Yorum Ekle
Yanıtını ekle
Nick sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 78
