Ana içeriğe geç
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Camera problem after screen replacement
Hi!
I replaced the screen for iPhone 6s plus. Now the cameras arent working. If I havent plugged the front camera connection in, then the both cameras are black. If I disconnect the front camera the rear camera starts working fine.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
If rear cam works after disconnecting front cam then you’ll need to replace the front camera assembly. Most likely due to a torn flex.
iPhone 6s Plus FaceTime Camera and Sensor Assembly Replacement
iPhone 6s Plus Front Camera and Sensor Cable
Replace a front camera and sensor cable compatible with the iPhone 6s Plus. Includes the front camera, secondary microphone, ambient light and proximity sensors. Part #821-00153-A. Görseli
Ürün
$55.99
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
So you think this is not a board issue? Will 6s camera work, I have one laying around?
tarafından
Yorum Ekle
Most likely you damaged the front camera assembly during the repair. This can be a hard piece to remove if you don’t have a lot of experience. Did you just pull it off the old screen? In the future, a little heat will help loosen the adhesive.
Puan 0
Yorum Ekle
Yanıtını ekle
Lauri Pahkala sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 177
