Ana içeriğe geç
The a7R II (model no. ILCE‑7RM2) is Sony's 2015 revision to their full-frame, mirrorless, interchangeable-lens camera.
29 Soru Tümünü görüntüle
Immediately after turning camera on - camera error..
Immediately after turning it on, it clicks up and down the shutter on the display and in the viewfinder a camera error is displayed. Turn off the power then turn it on. Tell me what could be the problem. Can I diagnose the camera on my own? Tried to shake the camera a little does not help
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
any error codes? what is the exact message? do you have a lens on the camera?
tarafından
No codes. message "Camera error.Turn power off than on." no matter with lens on camera or without.
This is almost a new camera. maybe 100 shots. Owner did't use it for a couple of years . Then he decided to sell it. everything was okay .he checked it. went to the meeting with the buyer on the bike. Turned on- there was this error.If a memory card is inserted, the red light flashes for a few moments.
recharging the battery from power bank works.
I'm not an expert, but it looks like the motherboard is working.
Inside there is a small ML621 Rechargeable 3V battery . May be dead.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Shutter is stuck it seems. Follow this sony guide: https://us.community.sony.com/s/question...
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
tried. didn't help.the sensor is not skewed like on youtube video,moves as if normal
tarafından
Yorum Ekle
Try to reset camera to factory default If possible. Remove battery and then press and hold power button for 10 second and then reinsert battery.
Different camera has different way to reset check manual.
Puan 0
1 Yorum:
unfortunately does not help. Nothing happens
tarafından
Yorum Ekle
Yanıtını ekle
Yuri Mironov sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 29
Her zaman: 1,477
