Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
iPhone 6S half backlight need solution
I got device which was having no backlight at all , after diagnosis I found the filter capacitor was Burnt instead of changing the capacitor with new one , I did direct jumper , this cause backlight came but the half side of lcd , how to get other half backlight of iPhone 6S
should I put the capacitor on , or change the backlight ic ?
Please share the solution I and Save the phone , as this is my first quation to the forum , please guide me, thank you .
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
There is no way to tell for sure without testing where the problem is. Backlight is brought to screen with one anode and two cathods. Each line protects the board with one filter, which is there to shield the backlight driver and components. Sometimes damage is limited to the filter, other times it goes further. Bridging a filter is a bad idea as any injury to the screen next time will likely directly destroy the backlight driver, capacitors, inductors and so on.
You can try replace all filters, if backlight is still half faulty you’ll have to dig deeper in the circuit.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
i change one capacitor , could you tell us which is another filter capacitor of backlight
tarafından
@doctorgadget You'll have to replace FL4211, FL4212, FL4213 or make jumpers for testing purposes. They're not capacitors though, they're ferrite beads. If you were to bridge a capacitor all you would get would be a shorted to ground line.
tarafından
Yorum Ekle
I would recommend you to replace the entire screen.iPhone 6s Screen iPhone 6s Screen Replacement
Replace a screen compatible with iPhone 6s. Includes all of the small parts preinstalled in the assembly. Features a 4.7 inch, 750 x 1334 pixel IPS LCD Display, Front Camera Assembly, Earpiece Speaker, LCD Shield Plate, Cable Foam Pads, and Sensor Bracket. Görseli
Ürün
iPhone 6s Screen
$54.99
Puan 0
Yorum Ekle
Yanıtını ekle
Ajit Sable sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 821
