Ana içeriğe geç
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Soru Tümünü görüntüle
My evice not power
i have my device liquid inside i change
power management integrated circuit, charging ic and 148AV ic
but still not work
can anybody help me what probleam
thanks
Update (03/19/2019)
Arabic:
لدي جهاز ابل ماك بوك برو 13 انش
موديل
A1287
انسكبت عليه ماء
ولم يعد يعمل
قمت بتغيير القطع التالية
لكن مازال لايعمل
فارجو المساعدة في اصلاه
مع الشكر
English:
I have an Apple MacBook Pro 13” model A1287
Water poured was spilled on it and now It no longer works
I have changed the following components:
  • Power management integrated circuit,
  • Charging IC
  • 148AV IC
But it still does not work
Please help
Gratefully
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
5 Yorum
I don't understand what you mean when you say "Liquid".
tarafından
water ،Fluids
tarafından
Please write in your native language and let us worry about the translation. fully explain what happened and what you have done or had done.
tarafından
If the water came in from the keyboard, have you replaced the keyboard?
tarafından
i change seam light red but not power
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
لقد قفزت بعمق في استبدال المكونات دون تحديد عمليتك بوضوح لمعرفة ما إذا كانت هذه هي المشكلة.
في حين أن هذه الرقائق تشارك في الشحن في كثير من الأحيان أجد أن MOSFETs هي التي تتضرر وليست الرقائق. هل اختبرتهم؟
أعتقد أن أفضل رهان هنا هو مشاهدة مقاطع فيديو قناة Louis Rossmann على YouTube لمعرفة كيف يتتبع الخطأ.
YouTube - Louis Rossmann Group
You have jumped deep into replacing components without clearly identifying your process on figuring out if that was the problem.
While this chips are involved in the charging often times I find the MOSFETs are what gets damaged not the chips. Did you test them?
I think your best bet here is to watch Louis Rossmann’s YouTube channel vids to see how he traces out the fault.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
thanks i will see
tarafından
Yorum Ekle
Yanıtını ekle
abdulkafi sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 185
