Screen wont sit flush
Hello. I changed the charging port and battery and now when i put the screen back on, in the down right corner it doesnt sit flush. Its raised a bit. Please help
Bu iyi bir soru mu?
Bu iyi bir soru mu?
This is usually caused by how the screen flex cables are aligned. Take a look at the flex coming from the screen and notice that there is a silvery “chip” on the flex. If it isn’t aligned properly, it will impede the way the screen sits on the housing.
Bu yanıt yardımcı oldu mu?
Where is the silvery chip ? I cant find it. Could you send me a photo of it please ?
oh, i know what chip. It seems that the chip from my replacement screen is a bit bigger than the one on the original one. What should i do with it ?
The arrow of the "Start Guide" practically points to it :>). Sometimes it just needs to be moved over a little bit until it rests in the opposite "hole" properly.
Did you use this because without it, it can cause it to pop up a little. iPhone 7 Display Assembly Adhesive
No I didnt but i dont think its the solution. I noticed that the silvery chip on the flex cable is a bit larger than the one on the original screen. I think it doesnt fit in because its too big. What should I do about it ?
Where did you get the screen from ifixit?
Ok if you didn't get it from here then get this. iPhone 7 Screen iPhone 7 Display Assembly Adhesive
OK, thanks :D
Keep me updated on how it goes.
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 205
