Ana içeriğe geç
Repair guides and information for the Nintendo Switch Joy-Con controllers.
Replaced shell, battery no longer works.
I replaced the shell of my right joy con and now it won’t turn off when not attached to the switch, no LEDs, nothing. I’ve checked the battery connecter and there’s no problem. Does anyone know where the problem could be?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I think you messed up your thingy that connects to the switch + has the lights. Is the ribbon in good?
Bu yanıt yardımcı oldu mu?
Puan 1
3 Yorum:
Having this same issue. I’m guessing Tom’s answer is probably the cause, but I’d like to know how you proceeded before trying anything for myself if you’re still around.
tarafından
Hey, I have the same problem. The ribbon was broken after I touched it with my finger. From the start, it was already kinked. Now the joy con has no function.
tarafından
I'm having this same issue. The battery isn't the issue on mine. I pulled it out and popped it into a different joy-con and it worked just fine. Were you able to test yours somehow or did you figure out what went wrong with your rail?
tarafından
Yorum Ekle
Some connection is probably not connected, watch the battery replacement and double check all your connections. Joy-Con Battery Replacement
Puan 0
Yorum Ekle
Yanıtını ekle
unnamed sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 2,789
